SP 540 Shirt printing??
Discussion in 'Roland' started by michsanford, Oct 11, 2010.
  1. michsanford
    michsanford Member
    332
    1
    18
    Oct 18, 2009
    Gastonia, NC
    Can you print on shirts with the sp540?
    We use it strictly for vinyl and banners, and I am interested in doing this.
    If so, what "attachments" do we need?
  2. zmatalucci
    zmatalucci Very Active Member
    heat press & the proper media... imprintables.com has everything
  3. michsanford
    michsanford Member
    332
    1
    18
    Oct 18, 2009
    Gastonia, NC
    Thanks!
  4. john1
    john1 Guest
    Yep all you need is printable heat transfer media and a heat press.
  5. michsanford
    michsanford Member
    332
    1
    18
    Oct 18, 2009
    Gastonia, NC
    Ok...I promise I am not a complete idiot...butWhat do you attached the media to when feeding it through the printer??
  6. m_s_p
    m_s_p Member
    48
    The printable heat press material comes with a backer attached to it. You would print, cut, weed, attach to the TTD mask then heat press. If you are just using the 1 color film you would cut with reversed image and the backer is the mask when you put it on the shirt to press.
