SP-540V Cleaning Help
Sindy
Hello All,
I bought a SP-540V nearly a year ago, and stupidly left it in the garage without keeping it plugged in, and think the pipes from the cartridges to the print heads have dried up, as I can not seem to get the Black to print.
I have tried doing all the cleaning options on the printer, and have done a manual clean using the cleaning kit, but still no joy.
Could anyone please let me know how I go about cleaning the pipes/tubes?
Thanks,
Sindy
Robert M
Pipes
Take the ink line off at the damper, throw the damper away and get a new on. Install a cleaning cartridge, get a large syringe and hook it to the onk line and start pulling fluid through the line. Once that is running clear, hook the syringe (get some soft tubing to connect to the syringe with about a 3mm id) and fit it over the nipple the damper was on. Push some cleaning fluid through the head. If all goes well, install the ink cart and put on the new damper and do a couple of powerful cleans to draw ink back into the head
