kustomkoncepts
I aneed to find a support group for others with this wandering print problem my Roland seem to be prone to..JK
I really have a lot of problems with my encoder strip and in turn get the wandering print problem. I have replaced the encoder 6 times in 4 years. also that service call 0110, Cariages Detached, and what ever it wants to tell me to keep wrecking material and me pulling out my hair.
I will admit I do have a static problem in my shop. I am on carpet. and get funny overspray paterns on the prints from time to time along with on the plastic parts of my printer, Cover and such.
I run a lot of Arlon GTX4560 and we all know how static ridden that material is. I even have to run a Tinsel static rod on the machine in the winter and Humidifiers to make it work.
I kinda know what my problem is but want to know of others with the same problem what situation or enviroment is your printer in? also people who have no problems with your encoder strips, what enviroment are you in? Separate room, type of flooring ect.
I want to see if there is a pattern to this problem and hope that it is not the machines fault that it is my fault because of the enviroment I try to run it in.
I am Climat controled and right now at 40-50% humidity and 70 Degrees in the winter it gets to 20-30% humidity also 70 Degrees. winter is when I really see the static and get shocks from it.
Thanks for any help.
