SP-540V Not communicating
Discussion in 'Roland' started by stephenj148, May 16, 2011.
  1. stephenj148
    stephenj148 Member
    281
    Jan 7, 2010
    Connecticut
    The Computer won't connect and reply to the printer. We've tried resetting the I.P address and tried new cables... still nothing. anyone have any ideas? It did print a status and test page from the control panel on the printer but nothing from the computer. Seems to be a communication problem, but we cannot solve it.
  2. Mike_Koval
    Mike_Koval Active Member
    629
    2
    18
    Mar 20, 2008
    Uniontown, PA
    Are you using a standard ethernet cable or a crossover. If memory serves me the sp-540v requires a cross over.
  3. stephenj148
    stephenj148 Member
    281
    Jan 7, 2010
    Connecticut
    Crossover, Brand new. The printer has been working up until last wednesday. Then all of a sudden, nothing.
  4. Mike_Koval
    629
    2
    18
    Mar 20, 2008
    Uniontown, PA
    hmmm, interesting. Are you hooked directly from printer to computer or using a router?
  5. stephenj148
    stephenj148 Member
    281
    Jan 7, 2010
    Connecticut
    direct to computer. now you know why were so confused!
  6. Mike_Koval
    629
    2
    18
    Mar 20, 2008
    Uniontown, PA
    what is the IP of the printer and computer?
  7. stephenj148
    stephenj148 Member
    281
    Jan 7, 2010
    Connecticut
    192.168.1.110
  8. J Hill Designs
    J Hill Designs Major Contributor
    15,549
    17
    they cannot both be the same - printer needs ffirst 3 sets of numbers identical, last one NEEDS TO BE different
  9. stephenj148
    stephenj148 Member
    281
    Jan 7, 2010
    Connecticut
    Printer is 192.168.1.110
    Computer is 192.168.1.105
  10. J Hill Designs
    15,549
    17
    again, first 3 same last one diff
  11. stephenj148
    stephenj148 Member
    281
    Jan 7, 2010
    Connecticut
    oops i meant 168
  12. J Hill Designs
    15,549
    17
    thats as far as my help goes =) im hooked up scsi (diff printer etc)
  13. Mike_Koval
    629
    2
    18
    Mar 20, 2008
    Uniontown, PA
    hmmm, not sure what has happened. Try turning the machine off both sub power and main power and leave it sit for a few minutes and turn back on.
    You may also want to try a different IP on the printer or computer...i have seen similar issues and this most of the time fixed it.
  14. Gabriel
    Gabriel Member
    275
    You could use PrintServer Netool. That is a small program who helps you identify(change)the IP of the printer, or see if the connection is ok between the computer and the printer.
    If you "ping" the printer, does it respond back?
