Sp 540v
Morph1
Print all
Just wondering if there are 64 bit drivers for SP 540V and will versaworks install functional on windows 7 x 64....
I looked at roland support website and it appears as there are no 64 bit printer drivers available...
Also can someone give me a few pointers of the order to install this unit on a new computer...
Printer driver first then versaworks ? or just versaworks and that will install the printer driver on its own...?
I am a mimaki user and all my printers run via USB or Firewire, I never set up a printer via cat5 cable.
any help would be appreciated.
thanks.
Versaworks will run on current 64-bit operating systems (Windows 7 and 8.x). Versaworks includes the printer driver for supported Roland devices, without need for a Windows-based driver.
Morph1
Print all
what version of Versaworks ?,
in means of installing the printer onto a fresh pc , what are the steps,
install versa select the right printer , read the ip address copy the address to versa , initiate
and done ? , is that the process, will the versa install the printer driver and the cutting driver ?
I got a separate cutting driver for windows vista which will work as I just tested it on a 64 bit win 7
thanks.
thanks.
Install the version of VW that you have on CD/ DVD. Configure the IP address of the device (SP540v). Update VW to current version (5.x?).
Northern Design
Northern Design Graphics
Print Driver
Roland did not make a driver for WIN 7 or Win 8 for the SP540V, they do make a driver for the VP or VS models
I have contacted them and they have no plans for development
