Sp300i printing on Reflective
CentralSigns
Never printed on reflective before. Can I use regular reflective material. Seems to work ok. Would I need to use high quality ink setting or fine with Standard. Any experience would be helpful, Thanks.
DRamm76
There are "printable" reflectives and there are some reflectives that are generally sold in the "vinyl cutting" lineup that work perfectly fine with the Roland. Go with the Oracal or Nikkalite and you can't go wrong. PM me with any more questions
Malkin
I have had good results using 3M 680cr.
Reflective tends to show imperfections and contaminations more then regular printed media.
cdiesel
Only a couple of the reflective films are recommended for printing. All others should be wiped with alcohol before printing to remove any contamination.
