SP300v cutting via VersaWorks question
Firemalt
Scanned through the manual, but didn't see anything on the topic I'm searching for.
When contour cutting, is there somewhere I can tell the SP300v to overcut a certain length? I'm getting a edges/corners that aren't getting cut completely.
Is this something in the VersaWorks settings or in the SP300v settings?
Could someone shed some light on this topic for me? Thanks for any information or suggestions in advance!
Ragnabrok
COuld be the blade offset. Normally it is set to 0.25mm, which works for a roland 45 degree blade. might have to trial and error to see what works best with your blade.
offset is in the same menu as cut force and speed.
