Sp540v pantone problem
Discussion in 'Roland' started by Red Ant NZ, Oct 20, 2010.
  1. Red Ant NZ
    Red Ant NZ New Member
    3
    :frustrated:Hi Does any one know how to get roland sp540v to print pantone colours correctly
  2. visualeyez
    visualeyez Member
    431
    23
    18
    Jan 23, 2007
    harbor
    I start by creating a new RGB document in illustrator. I then open up the swatches toolbox and open up the Pantone Solid to Coated palette and select the colors I need to design with. Do work, save design as a .pdf with a setting of "High Quality Print". Open file in Versaworks, assign media profile, and hit Print. Make sure your versaworks settings for color management have Adobe RGB 1998 as your default input profile, which is what you should be saving with from Illy. It's pretty darn easy once you get it figured out.... Not all pantone colors are within your printers color gamut.
    -Keith
  3. ProWraps
    ProWraps Very Active Member
    3,556
    Sep 30, 2009
    San Francisco, CA
    your printing digital. cmyk. there is no pantone.
    the printer is the least of your worries.
