J Hill Designs
One problem remaining is when printing solid dark colors there are light streaks running parallel to the feed direction, (perpendicular to the carriage travel), at 12 - 21 - 30 and 39 inches across the print whenusing bi-directional printing.
if its only in bidi mode, then its probably chromatic banding - clean the encoder strip, and double check bidi alignment.
if its uni and bi, then it could be heat causing tunneling in between the pinch rollers.
