Speed up Firefox.......
Discussion in 'General Software' started by Shovelhead, Jan 19, 2008.
  1. Shovelhead
    Shovelhead Major Contributor
    10,882
    16
    I thought at first this was the coding for the FASTERFOX add-on.
    Dramatically sped up page loading. Most pages load instantly.
    "If you have a broadband connection (and most of us do), you can use pipelining to speed up your page loads. This allows Firefox to load multiple things on a page at once, instead of one at a time (by default, it’s optimized for dialup connections). Here’s how:
    * Type “about:config” into the address bar and hit return. Type “network.http” in the filter field, and change the following settings (double-click on them to change them):
    * Set “network.http.pipelining” to “true
    * Set “network.http.proxy.pipelining” to “true
    * Set “network.http.pipelining.maxrequests” to a number like 30. This will allow it to make 30 requests at once.
    * Also, right-click anywhere and select New-> Integer. Name it “nglayout.initialpaint.delay” and set its value to “0?. This value is the amount of time the browser waits before it acts on information it receives".
  2. CW Graphix
    CW Graphix Member
    101
    That worked Great! So much faster!
    Chris
  3. PMG
    PMG Very Active Member
    2,453
    Nice thanks Shovel!!!!:thumb:
  4. slipperyfrog
    slipperyfrog Active Member
    552
    Jul 18, 2007
    Las Vegas
    Nice tip. Thanks.
  5. Shovelhead
    10,882
    16
  6. WhiskeyDreamer
    WhiskeyDreamer Professional Snow Ninja
    3,550
    80
    48
    Aug 6, 2007
    Riften
    thanks shovel....
  7. thesignexpert
    thesignexpert Active Member
    841
    2
    ShovelHead... mega thanks for a great post! My Firefox is zipping along at killer speeds now.
    Tim Evans
    The Sign Expert .com
    "Practical Help for Sign Professionals"
    Pro Sign and Graphics
    "A Pro Sign made Easy"
  8. Replicator
    Replicator Major Contributor
    10,230
    9
    38
    Nov 19, 2006
    Sun City, AZ
    Seems a little bit faster, not that much !
  9. MobileImpact
    MobileImpact Active Member
    759
    Thanks brother!
    Flying along now!
  10. The Big Squeegee
    The Big Squeegee Major Contributor
    4,960
    107
    63
    Oct 10, 2005
    Lawton, OK, USA
    Thanks, works great!
  11. Deaton Design
    Deaton Design Very Active Member
    1,602
    2
    Cool. Sure flies now.Thanks!
  12. Shovelhead
    10,882
    16
  13. Mason
    Mason Very Active Member
    2,037
    Aug 11, 2005
    Boston
    Thanks Shovel!!
  14. WVB
    WVB Very Active Member
    2,749
    THX for the great info..!
  15. Signsforwhile
    Signsforwhile Very Active Member
    1,401
    Feb 17, 2006
    New York
    :thumb:
  16. Rhino
    Rhino Active Member
    535
    1
    Neat-O Thanks!
  17. Service Sign Co
    Service Sign Co Very Active Member
    2,311
    Nov 9, 2006
    Southaven
    :cool1:
  18. nxtremesign
    nxtremesign Member
    230
    very Awesome , tanks a bunch!!
  19. animenick65
    animenick65 Very Active Member
    1,320
    May 18, 2005
    Boston, MA
    Another tweak is to create a new integer like you did above and type
    "content.switch.threshold"
    then set the value to 1000000
    This allows you to actually start using a page before it is done loading.
  20. Shovelhead
    10,882
    16
    noted...added that to my arsenal....:thankyou:
