Regarding Roland Spot Colors and special effects
In this case, from our understanding with certain postscript features, there is no way to use both the drop shadow effects (or other special effects) with RVW spot colors.
The only option would be to use any CMYK or RGB color instead of the RVW spot color that can be rasterized with a transparency or special effects.
When using regular assigned process colors in Adobe Illustrator, the best way to get the purest colors when printing (aside from the Roland Spot Color Library) is by going into the "Color Management Properties" settings in Roland VersaWorks and click the check box to turn on “Preserve Primary Colors” . This will give you for example a bright pure Yellow.
Feel free to PM me, or give Tech Support a call at (800) 542-2307 - Press '2'.
__________________
Robert Ozankan
Senior Product Manager - Color Products
Roland DGA
