Same here. The 3155 works well.
I'm assuming the OP is referring to adhesion promoters for UV ink - which doesn't apply to slapping vinyl on coroplast.
StellaFB700, what kind of issues are you having that would require you to prep coroplast sheets? As we all know, direct printed coroplast is one of the lowest cost/margin products you can produce on a flatbed, and having to prep each sheet quickly eats into profits.
What kind of coroplast are you using? Is it corona treated? I have heard of adhesion problems with the FB inks but there should be a good coroplast out there that will work for you without the need for prepping. Personally I prefer Coroplast brand and we have no adhesion issues with our Oce Arizona, but I realize the inksets are quite different from one another. We've also had good success with Inteplast but our dealer no longer carries it. I find Coroplast brand has a nicer white point and the finish accepts ink better.
