Sprinter Door Handles
DirtyD
Soo.. I don't know how to remove these.... Couldn't find instructions through google... Any help? Thanks
Eric H
Should be a small plastic cover in the door edge, take that off. There is one fastener that needs to be loosened and the whole handle comes out. Similar to the new fords if you've done any of those.
T
TonyC
Guest
Been there/done that
As mentioned, open the door and in the jam you will find a small rubber plug. Remove the plug and you will find a bolt. Remove the bolt. I then found I had to use a punch or socket to "knock" the handle loose. I placed it where the bolt was located and moved the handle about a half inch. the handle will then be loose enough to remove.
I did find this technique through google search.
