Square Steel Tubing - best source?
Billct2
Around here there are a few steel wholesalers that deliver. If it's a small job there's a place that has cut offs and leftovers, usually with some surface rust though.
rjssigns
If there isn't a steel supplier in your area look for the nearest welding shop. I used a local weld shop for years until SI Metals set up shop near me.
Best part about a weld shop is usually for not much more than the price of the steel they will cut and weld what you need.
