Geminis076
Hello, I recently upgraded cutters from a Master Tiger 1000 to a Graphtec CE 5000-60, my Master machine quit on me
. I've always created vector images in Macromedia Flash, then would copy and save them as .AI files in my Illustrator 9 because .AI files are good files for my SignGO lite software to read. Results were very good.
If I zoom in very closely in Illustrator, I can see lots of tiny squiggles in most areas where there are curves in the design. Looks differently in Flash, in Flash the lines are very clean and squiggle free, there are very little plot points. As a test I created a quick circle in Flash with the circle tool which created a clean and pure circle, but when copied over to Illustrator, several areas of the clean curves now had squiggles. Grapthtec unfortunately includes the squiggles in the design, I guess the squiggles have always been there but I never had any squiggle issues with the Master Cutter, very obvious with Graphtec cuts.
Here's links to 4 photos of samples in both Illustrator and Flash:
(Flash sample one - without anchor points)
(Flash sample two - with anchor points)
(Illustrator sample one - without anchor points)
(Illustrator sample two - without anchor points)
I can try to play around with increasing the speed but it so far doesn't seem to be helping. Are there any settings I can try that may help? I'm new to the Graphtec machine and using the Cutting Master 2 plug-in. Would really hate to have to re-create all my files, I'm not sure how to create non-text images in Corel or Illustrator - Flash has been really great and easy.
Thanks for any information!
