SSK Design Tech 60 aka GRAPHTEC
149motorsports
Does anyone still use these cutters? I just bought one and cant get the settings right, my ce2000-60 i set up fine.. this cutter keeps cutting jagged edges, and can't get the lines straight to connect.. i replaced the cutter strip and i used the same blade holder and blade that works perfect in my c2000-60..thanks for all the help!
need some settings you guys use..thanks!
CS-SignSupply
Settings really should be the same while it is possible that the cut head assembly is loose.
What settings do you have now?
149motorsports
HI,
I just went and yanked on the part that holds the blade holder and unti and it did yank up.. i went and yanked on my ce2000-60 and it didnt budge one put.. you maby be right, how do i tighten this up?
thanks for the time!
