Need Help New Guy Starting Point and Finishing Point Connecting (incomplete corners) mimaki cg-75fx
Discussion in 'Mimaki' started by Ryan J. Gill, Jul 9, 2020.
  1. Ryan J. Gill
    Ryan J. Gill New Member
    3
    Jun 29, 2020
    Seattle
    We've run this plot a thousand times, over the years - and all of a sudden the starting point and finishing point are no longer connecting, thus we have incomplete corners -
    its a Mimaki cg-75fx on the second cut -
    EPS File in Illustrator with the Final Cut 9 software
  2. Solventinkjet
    Solventinkjet DIY Printer Fixing Guide
    4,190
    784
    113
    Aug 2, 2011
    Denver, CO
    Check your blade to make sure the tip's not broken. Then double check that your offset setting is correctly set. If you changed blade angle recently and didn't change the offset, that would also cause the same issue.
  3. MikePro
    MikePro Major Contributor
    4,975
    235
    63
    Feb 3, 2010
    Racine, WI
    i've had that happen when i leave overlaminate hanging off the edge of my print, as most times my laminate is slightly bigger than my digital media or i'm not dead-nuts square with the print.
    any drag on the plotter, will result in disconnected cutpaths
