gabagoo
I have the same problem every time I run white on static cling and it does not matter if it's Gerber or Duracoat. The first letter of every run has wrinkles of dropouts running through them making then entire decal useless. It seems to me that the material seems to have problems sitting down properly after each decal is finished. By that I mean the heads rise the material moves forward and when the heads go back down, for some reason there is a continuous wrinkle in the foil that will not flatten out until it prints 2 or 3 inches in. I had the same issue last year with this exact job. I have the heat settings to light but maybe I need to go even lighter. Not even sure if that will fix it. Anyone else experience this and if so how did they manage to correct it?
