Static cling cutting problems
Discussion in 'Newbie Forum' started by rtorrington, Jun 23, 2010.
  1. rtorrington
    rtorrington New Member
    2
    Hi :
    We are having difficulty maintain alignment when trying to cut our printed static cling vinyl decals. Any suggestions?
    Mutoh Value jet printer
    Mutoh cutter
    Flexi pro
    Print/cut job 300 1x1.5" decals,
    Alignment starts accurately but gradually drifts,
    We tried putting premask on the front of the cling where the rollers travel with some success and also added it to the backing. But there is still drifting.
    Thank you for your help
    Bob
  2. Replicator
    Replicator Major Contributor
    10,230
    9
    38
    Nov 19, 2006
    Sun City, AZ
    smaller batches and maybe even holding the material taught as it comes of the cutter !
  3. The Big Squeegee
    The Big Squeegee Major Contributor
    4,966
    109
    63
    Oct 10, 2005
    Lawton, OK, USA
    Welcome from OK USA
  4. randya
    randya Very Active Member
    2,060
    3
    38
    Apr 6, 2007
    Arizona
    What speed and force are you using?
    How old is your knife blade?
    You might even want to extend your knife distance out from the holder.
    Perhaps the holder is dragging the material.
    I would start by slowing down the speed and the acceleration.
    Your best bet is to try and observe it during cutting.
    Look for the material bunching up at the knife.
  5. rtorrington
    2
    Thank you Pat:
    No luck on the short run, though it isn't as bad.
  6. cdiesel
    cdiesel Very Active Member
    3,515
    Jan 28, 2005
    Phoenix, AZ
    We have had issues that were fixed with shorter runs using a slower velocity. The static material creates quite a bit of drag across the platen, which I suspect is the culprit.
  7. thewood
    thewood Very Active Member
    1,781
    Dec 28, 2005
    Tennessee
    Have you calibrated your printer's media feed for the cling? Cling will feed differently than pressure sensitive film, and an uncompensated print can result in inaccurate cuts in the y axis.
