WildWestDesigns
The least thing a rival vendor can do is provide import accuracy between features that are duplicated between the two applications.
I think though, that how features are implemented between the 2 applications would also play a part. If features that may be comparable are coded differently when importing in the competitors format may cause breakage.
That is for sure a pickle. Part of the process of saving into other formats includes that as some things are accepted into those formats. I don't see that issue every going away, it may actually only be getting worse due to the user base out there. I dunno.The difficult thing with ditching Illustrator is the application has so many unique features that users often bake into their artwork without making any attempt to expand or flatten.
Inkscape is the only application you mentioned that fits into mainstream sign making purposes -which mostly calls for 2D vector graphics work.
GIMP and Krita I think would also be applicable. Blender for CNC work. I do have some plugins that are for CNC work. With GP in Blender, that could also be utilized for 2D work. I mainly use it for 2D frame by frame animation and game sprite work, but it can be used in other ways. Their used to be a way to export SVGs as well from Blender, I think they are trying to reintegrate that back into it.
Inkscape is the only one in that list which directly compares to Adobe Illustrator. I personally don't like its user interface and limitations; I can get things done a whole lot faster in CorelDRAW and Adobe Illustrator. The only advantage I see in Inkscape is that it's available for free.
See, you miss the best part of Inkscape and the others. Granular control. You can change the UI on all of them. Don't have to recompile or anything like that. I agree, I don't care for the default look of Inkscape. Layout doesn't bother me, but icons (I'm not much of an adwaita person) I do have my issues.
You don't even have to do it yourself if you don't want to, can't or whatever the reason may be. A lot of people have done at least the basics for you to where it's just drag and drop of files in respective directories.
Are you taking these programs "as is"? That tends to be the thought process of most people, it's "as is", so if it sucks "as is", they drop it. Where these programs come alive is with scripting (mainly python, which is a fairly user friendly language, I'm more of a JS person myself) and with extensions/plugins/addons.
If you are using say vanilla Inkscape, I would never recommend it for print work. The mere fact of it's "master file" precludes that as an option (as it would any open source vector project, say for instance Karbon). One would need to either use it in conjunction with Scribus (how I do it) or use a plugin, there is one, I mentioned it to Johnny in another thread, can't think of it now, way past my bedtime. Mind isn't sharp at this time.
Photoshop figures in to a lot of design for large format printing, as well as design for LED signs. The rival pixel-based image editors just don't compare well to Photoshop. I prefer the features and interface of Photoshop.
GIMP would be the closest here. I don't like this interface at all. There are themes out that for GIMP to get it to look like Ps as well. You have to script GIMP, again, mainly python, to get it more usable. You can get quite a bit more work down this way. Can also get all of this programs scripted to where they run via CLI (you can invoke the script via GUI, it just opens up a terminal automatically and runs the script) less drag on resources, so can actually run multiple processes since it's not also calling much graphic demand as well.
Some people are afraid of CLI (I grew up during the DOS days, so I wasn't totally a stranger when I get to using it more now), but not matter what platform you are on, it is the most efficient and powerful means of doing something. You can write and invoke the script via GUI though, the CLI portion is down automatically. Don't have to do it, that's just another option.
Now, some people also consider Krita an alternative to Ps, I do not. It is closer to Corel Painter then Ps. Some overlap, but definitely not enough, for me, to consider it an alternative to Ps. I do know of one user on here that uses Painter, so even in that regard, Krita may not be all that out of place. I dunno.
I do keep on mentioning scripting and plugins etc, there are a lot of those already done (may not have one that you need out there, that's always possible), but when I say you, it is the generic you. Don't have to do this yourself if you can't, not inclined etc, but would have to go looking to see if they exist.
The tight integration Photoshop has with Illustrator and InDesign isn't matched by any other software vendor. Freehand was the only drawing program that came close to matching Illustrator in terms of integration with Photoshop.
It's getting better between GIMP(or Krita depending on who you talk to), Inkscape and Scribus. Not nearly as good as Adobe, but considering it's 3 separate projects and don't nearly have the history as Adobe, I can understand that to a point. But I do miss that smooth of an integration.
That's your own case. I was talking about most users in general who balk at using Adobe CC. Software cost is the #1 factor. These folks don't see the value Adobe is offering for $54 per month. They're actually delivering significantly more than what was bundled in the Master Collection of the previous Creative Suite model. That cost around $2000 to buy and $600 per year to update, yet it was still missing a few things and didn't have squat for fonts. The Adobe Fonts thing is worth a bunch just on its own. So I see the CC thing as an investment to help our company make more money.
Hard to tell how they would have handled it if they had kept CS. I'm sure that portion (Adobe Fonts), would be a subscription addon.
The one thing that I would be concerned with is that they could remove or adjust any one of those features down the line. I am not saying that they will for those specific features, but that's a possibility. Things can change at a moment's notice and users don't have quite the reaction time that they once had with major releases, especially with the x-1 update schema. A little bit of time, but not quite as much.
I may place to much of a high value for something that may not happen, but that is just what I would be concerned with.
Now, does that happen in the open source world, yes it does, but the biggest difference is if it is something that a lot of people use/desire/what have you, typically the community would put it back in. The most current example of this that I could think of is BGE. Deprecated and removed officially from 2.8, but a project (UPBGE) has brought it back and working on getting it in 2.8 and modernizing the original code base. There is no possibility of that happening with anything in the closed source world. That is a huge advantage. At least in my mind. Not everything happens that way, but that potential is always there.
That still ends up being another knock against Inkscape in a comparison to Adobe Illustrator. As far as I can tell Illustrator is still the only vector drawing app that provides full support for OpenType Variable fonts.
Remember that's officially. I haven't looked into it too much, but there could very well be a plugin that supports it fully or is certainly adding to it beyond what officially Inkscape would do.
