Steamer Vinyl Remover
I was wondering if anyone is using one of the steamers to remove vinyl and wraps. What are your thoughts? Does it work well? Is it worth buying?
gabagoo
steamers work pretty good although sometimes they can seperate the adhesive from the vinyl making more use of rpaid remover, but still prefer working with a steamer over heat gun where possible
Long as you get a good one with larger capacity well as adjustable temp output, you'll be kicking yourself in the arse for not buying one sooner. BIG TIP..... DO NOT buy any of the ones any of the sign suppliers are offering. Do some research on your own and you'll find the same ones cheaper from other vendors (just NOT NEVER AND NO WAY any of the cheap knock off crap Amacrapazon offers) and better yet you can go direct to the manufacturers on the bigger commercial steam units.
