Stencil Cutouts???
splizaat
Does anyone have a good material to throw through a plotter and use as a reusable stencil? Doesn't have to be rigid per-se, but does need to NOt be peel and stick. Something I can plot out and have a customer use as a spray paint stencil over and over again just by either taping it up or holding it up to the substrate...
signmeup
Try goggling something called see-temp. It was used by R/C airplane builders to make stencils as you describe. Only they used an Xacto knife.
Sticky Signs
I've made lots of stencils by hand. Sometimes cutting the vinyl, weeding the stencil part and than cutting the release liner by hand. I've also done the same thing but mounted the vinyl to either styrene or sintra.
Now I get my buddy to make them for me with his laser cutter. He uses a fairly rigid piece of styrene that is very re-usable and the quality of the laser cut is awesome. Only down side is that he's limited to the size of a stencil he can make. Of course most stencils are pretty small anyways.
CentralSigns
We have made some out of polystyrene, a white ridgid plastic. It makes a re-usable stencil. Our Summa cuts it ok, 300 lb pressures, will not cut through it, you still have to pick out the pieces. We do them for companies that do product testing and have to spray paint the test and section number on the test item. It is very time consuming to make them I would think a CNC router would make nice ones and material thickness could be increased to the max the material is avaliable. that would insure a long lasting product.
Mosh
+polystyrene, be sure to ROUND CORNERS or your blades with be messed up.
Done it a few times with good results. just babysit the plotter while you cut and run at a lower speed.
TyrantDesigner
Art! Hot and fresh.
as mosh said, round your corners, also make sure your blade is a 45 degree blade, you can snap a 60 degree blade tip. and slow it down to snail speed.
nashvillesigns
Making America great, one sign at a time.
guys. i used to beat myself up over this stuff. Customcutstencil is so cheap i decided it wasn't worth ruining your plotter for. instead of shelling out 400 bucks for a roll of material vinyl plotters are really not good for cutting, i still made a killing reselling them.
you end up killing a blade, stretching out the bands, and shortening motor life. unless your name is Dr. Evil and you have a "lazer" save a plotter. :)
signmeup
Hold the phone... your Summa has 300 pounds of downforce??!! Impressive! (I only have 150 pounds of downforce soaking wet.)
ddarlak
Go Bills!
i use .020 styrene, slow down the plotter, round the corners, have the plotter reset back at the begining and run it a few times, then it's crack and peel.....
i think its like $10 for a 4' x 8' sheet
Tony McD
Had posted on this subject on another thread a couple months ago, but can't seem to find it.
The last stencils I made using sandblast mask. Cut two copies, one in reverse, and stick them back to back. Makes a pretty good flexible stencil.
petepaz
we do the same but with .010 and we use pvc or styrene
Pat Whatley
What he said except I cover the styrene with vinyl first. Styrene cracks and tears too easy, the vinyl really helps.
Of course unless we're damn good friends or you've got incriminating pictures of me I'm not doing you a dang stencil anyway.
