R08
Fred asked if I could show how used the Cutout Lab on the Flames sample from his Real Fire DVD package . see his thread: http://www.signs101.com/forums/showthread.php?t=32788
This is a way to clip an object and retain a transparent outside edge which automatically antialiases to any background color (including bitmap image)
I'm no pro at this.. I just learned it tonight but here goes: (Im using X4 version btw)
Step 1. Open file in photopaint and select the cutout lab in the Image menu. Zoom in until it's comfortable.
Step2. Select the highlighter tool (top left) and generally go around the part of the image you want clipped
You can include little bits of orphan flames if you want. You'll notice I highlighted a couple of dark areas to allow these areas to be a bit more transparent also. You can change the size of the nib to get different results. The fill and highlight colors are only for visibility they will not affect the final output.
Now select the fill tool and select inside the flame area
It will turn the fill color (color is for show only)
Mine is purple and turns the flame magenta
Now select preview and see what you've done. You can go back (bottom left controls) and change it if you like or tweak it using the top right detail tools (brushes with the - or + sign)
When you're satisfied press the ok button and you're good to go.
It's really a lot simpler and smarter than I originally thought. Very powerful indeed and easy to use.
Hope this helps.
Hope this helps.
