Sticky situation : Controlling humidity levels
GP
Anyone have a problem with humidity controls like we do?
Printing and work room is approximately 1000 sq feet.
Current humidity is 73% but it has been as high as 85%.
I do not own the building and we will most likely be leaving in a year, so I don't want to install a central dehumidifier unit. I cannot plumb an over flow line to empty the bucket, so I need something on the larger side.
Anyone start off with these numbers and invest in a decent system to control them?
rjssigns
Do you have and AC unit or do you leave the doors open? If you don't have AC get that first.
For 1000sq ft I would go to Home Depot or Lowe's and get a couple of their biggest dehumidifier units and put one on each end of the shop.
Tip: If you need more water capacity raise the dehumidifier so you can drain into a 5 gallon pail.
Signed Out
you should be able to run a hose from your dehumidifier and bypass the bucket. we have ours near an overhead door and the hose runs inbetween the door and rubber seal to the parking lot.
10sacer
I would kill for 73% humidity and I am in North Carolina.
We crank two humidifiers all day and struggle to get to 50% RH
