Signed Out
In the process of researching stomp shears and whether or not our shop would benefit from one. Currently we have a steeltrak wall cutter which works great for coroplast, and sintra, but doesn't leave the nicest edge on dibond. It used to cut dibond better when it was new, but even after aligning and replacing cutting wheels it leaves a bit of a raised curled edge. We also have access to a big 10' hydraulic shear at a welding shop next door, where we cut our aluminum and more recently have been cutting a lot of our dibond on it too. However it isn't ours and access is somewhat limited, dirty, etc.
So a couple of questions: Does anybody prefer their wall cutter over a stomp shear for cutting dibond? Anybody have an idea of why our steeltrak might not be cutting as good a it should? Like said earlier we have gone through all alignments and replace the cutting wheels. I have tried talking to keencut's customer service, but guy was litterlay zero help, suggested talking to our dealer.. Talked with dealer and they said they can go through all the adjustments, make sure everything is square etc... IDK
So we are thinking about adding a 52" stomp shear to our shop, looking closely at the tennsmith. I would like to test one out before buying one, but there aren't many around. We would be looking to shear .040-.080 alum, 3mm and 6mm dibond, coroplast, and 3/16" polycarbonate. Can anybody with expierence using a stomp shear comment what they do and don't like about it.
Any info would be great.
Thanks,
Thanks,
