Stomp Shear.
Farmboy
Tired of the inconsistent cuts from my Fletcher and replacing the bushings has done little to help.
My question is, can a shear cut 6mm ACM and also coro without crushing the edge. I'd like to not use the Fletcher at all and free up the floor space.
Thank you.
Notarealsignguy
Arial - it's almost helvetica
We cut 6mm with a hydraulic shear, stomp should do the same. Coro I dunno, the hold down will probably crush it
Billct2
We cut 6mm on our 4' stomp shear. Coro doesn't work though.
I had been holding out for a used 8' stomp shear for years but had a chance to get this 4' and so glad I did, realy speeds things up.
Notarealsignguy
Would probably need two people to step on it but price is pretty decent
JBurton
Signtologist
I cut coro on our ancient 5' stomp shear, no real issues with the edges unless you go slowly...
somcalmetim
I got a handheld electric metal shear for 4mm ACP panel and a handheld electric concrete shear for thicker stuff...got to clamp a straight edge on the sheet to run a straight cut and it takes an 1/8" ribbon out of the center with each cut but it leaves a fairly nice slightly rounded "safe" edge to the ACP panel...it can also do curves....I havent tested it on coro though, I assume it would crush a bit....we could never get our Fletcher to cut ACP straight...
A hot wire cutter like they use for airplane foam would likely work better for coro...
