Stripe on a pick up bed.
OADesign
Hi All,
Hope you are having a great Friday.
Hoping someone can help me out here. So I have a project where I'm putting a 4" stripe down both sides of a bed on a pick up truck (Tundra). So you know the area where the back of the bed turns? Right at the brake light where it turns to meet the tailgate? Well I'm accustomed to putting relief cuts there. Never had an issue before. But this one guy is giving me a hard time about it.
So I guess my question is, do any of you have any tips to turn this corner with out adding a relief cut? I am using AutoMark.
slappy
cajun312
The Tundra bed kind of curves inward where you go around the corner, probably making the stripe go upward on the tailgate.
SignProPlus-Chip
Wouldn't the stripe stop at the tail light, or does part of the stripe go above or below it?
I just did a full wrap on a Tundra, and I can't figure out where your problem is. Either remove the tail light, cut the stripe and start new on the tailgate, or heat the curve, pull it straight then trim it out.
