stroke data converted...how do you break it apart?
gabagoo
I have a file that the customer must have used a stroke to create my cutline, but he converted stroke to outlines before sending. When I designate it as a contour cut it makes 2 cuts...an inner and an outer. I cancel the operation and try to break the shape into 2 pieces but nothing highlights under group or compound. How do I break the path to get rid of one of the shapes?
Rick
Release compound.
Delete inner stroked outline (if there are no "holes" just weld it all together) if there are holes, after removing unwanted inner cutline, compound shape again.
gabagoo
none of the compound options highlights. it is very strange and I have seen this before. I could just let the cutter cut the 2 lines but they are so close we take the chance of actually scoring the backing paper.
mosignman
sometimes it may have a mask, don't know why but it's happened to me. Try to unmask first then ungroup or uncompound.
gabagoo
not masked not grouped not compounded.. hell with it, I deleted them and redrew them, but it is an illustrator issue that when the stroke is coverted to an outline it makes a line on both sides of the stroke and somehow they are stuck together without touching and flexi has no idea how to break them apart.
Kwiksigns
wookie
Usually when that happens, I just use the scissors to cut the outline, then join the points back together and everything is in pieces... Don't know why it works but it does.
thewood
I've encountered this glitch when outlining strokes in Illustrator as well. You may not be able to separate the two paths created when converting a stroke to an outline because they are actually connected. Sometimes, you can delete the offending nodes and separate the paths.
gabagoo
your correct but with these I found no connection. In future I tell people to leave the stroke data, I will deal with it
