STS White Ink Issues, LUS-170
Smoke_Jaguar
Just a heads-up for people using STS Inks for their UV printers. If you're using their white ink, check the barcode tag underneath the main label and make sure it doesn't say "SB.UV.655.5000.W" This ink is WAY thicker than spec and has been clogging like crazy and according to STS, the ink is incompatible with the application. I guess there was some kind of mix-up. Not had issues with CMYK or clear inks thankfully.
SB.UV.550.5000.W should be fine.
Smoke_Jaguar
Mimaki has also had some pretty rough batches as well. White ink is just inherently a gamble.
