artbot
hoping someone out there knows of some mimakinese secret to solving a vacuum leak at the cap. recently i broke down my printer, did some mods, put it all back together. did an ink fill (CMYKx2) and noticed that the K and C weren't filling. did the usual isolation, extensive isolation:
swapped cap tops
swapped dampers
swapped pump lines
even swapped head locations!
readjusted head height
brought capping station to factory height (couldn't really be height because other heads (M and Y) had no leak. but did it for scientific method)
brought capping station up .030 and .060 with shims
moved capping station around to other positions
then change out to new cap tops!
even took a head manifold off and retightened!
today i was really excited because i'd decided that my captops must be tool old and replacing the would do the trick (replaced all four cap+tube, not just seal) ...no. still hearing very tiny sucking air sound. grrr...
i'm stumped.
i've even used a homemade stethoscope to make sure that the air noise is coming from between the head and the captop.
what else is there to check? this isn't rocket science.
swapped cap tops
swapped dampers
swapped pump lines
i'm stumped.
