Sublimation Heat Press Question?
Discussion in 'Miscellaneous Hardware' started by Steve C., May 30, 2005.
  1. Steve C.
    Steve C. Very Active Member
    3,278
    3
    Am getting in on Datcat's Heat Press Deal.... wondering if you need a special press for Sublimation printing or will any Heat Press work?
  2. TerryStolmeier
    TerryStolmeier Member
    126
    From what I understand you don't need a special press to do dyesub. The difference is in the application media. (I may be wrong)
  3. dynawg
    dynawg Member
    101
    Steve,
    I'm in as well... From my reading the specialized stuff is the inks and the substrate. However, looks like you need an Epson printer to run the inks. The heat press is a heat press, is a heat press... But I'm sure there is temp/time settings involved as well.
    Bob P.
  4. 3CGraphics
    3CGraphics Member
    381
    May 23, 2004
    ATL Area
    It must heat to 400 degrees is all. If you are going to do ceramic tiles and thicker items you really need a floating bottom platten or a swing away/drawer press. dynawg is correct, substrate is coated or certain other synthetics and dye sub ink which is run through the epson style head as it doesn't heat the ink to print it.
    Steve
  5. Fred Weiss
    Fred Weiss Merchant Member
    20,919
    544
    113
    Sep 11, 2003
    Olympia, WA
    That's interesting, since I know Iimak (Duracoat) offers dye sub ribbons for Gerber Edge and that uses heat to print.
  6. Steve C.
    3,278
    3
    Thanks to all for the Info.
