Summa D140FX vs D140R / D160R vs Something else
Discussion in 'Summa' started by PrintItBig, May 12, 2020.
  1. PrintItBig
    PrintItBig Member
    230
    Sep 29, 2012
    UK
    Hi,
    We're considering buying one of the below cutters to run alongside our Latex 360.
    It will mostly be used for print and cut graphics, printed and laminated floor graphics and very occasional standard vinyl. We would want to kiss cut but also have the option to cut right through the material.
    We'd be running the machine through Caldera.
    I know the FX model is more limited on material sizes but unless I'm missing something I can only see this being a very occasional minor annoyance and the FX machine is quite a bit cheaper. I've spoken to a couple of resellers and they have advised against the FX machine as it's "just a cut down version of the R" saying it hasn't got as many motors and won't handle heavier material. Not sure how true this is?
    Will we be OK with the FX model (as it's quite a bit cheaper) or would the R model be more suitable?
    Or are we better off with something else perhaps a Graphtec (which one of the reps was desperate to sell me).
    Summa D140FX
    Summa D140R / D160R
    Something else? Graphtec?
    Any advice would be welcome.
    Thanks.
  2. FatCat
    FatCat Very Active Member
    1,997
    194
    63
    Feb 12, 2007
    Columbus, Ohio
    Have had our D-140 for nearly 7 years now - excellent machine for cutting vinyl and prints. The only thing I wish was that I had gotten the 160 version to be able to cut 60" rolls, as we do quite a few wraps and all the color change materials are 60".
  3. PrintItBig
    PrintItBig Member
    230
    Sep 29, 2012
    UK
    Thanks for the reply.
    How do you find the machine cutting heavier stuff like laminated floor graphics?
    Does it handle it OK?
  4. FatCat
    1,997
    194
    63
    Feb 12, 2007
    Columbus, Ohio
    Yes, it handles pretty much all materials well. I will note, that for thicker and harder to cut materials we often switch to the 60 degree blade to aid in cutting. (Reflective, Phototex, extra heavy laminates, etc.)
    For floor graphics the textured laminate we use is no problem for the standard blades, but if you were doing a lot of cuts I might swap out for the 60 degree.
  5. Eugene Tan
    Eugene Tan Just Sharing
    12
    Feb 7, 2020
    Thailand
    D140FX is basic enough for your work. Thicker materials may be a bit slower as it only has the X motor... btw, HP OEM this model...
    It is as advertised:
    No gimmick
