Hi there, at my workplace I use a Summacut D160R to cut things printed with a HP Latex 365 but recently it seems to be getting worse at cutting where it's supposed to.
For example - just did a vinyl print of about 2m length, I had a 10mm bleed on it, but from the start to the end it still drifted off enough I've got whitespace on my cut graphic. These seems to happen with anything over a meter or so.
I thought the point of the OPOS barcode was to also know if the vinyl loaded isn't quite straight and then corrects it (though I'm careful to try and put it in as straight as possible before lowering the handle)
I've tried recalibrating OPOS on the summa panel (l did just before this 2m print that went wrong), what should I try next to try and diagnose/fix the problem?
