Summa S t140 Knife height issue
Martin Fitton
I am trying to set up my summa for flex cutting stickers i have just fitted a new blade and have manually set the depth to just below the foot as instructed and done a test cut at 10g which kiss cuts perfectly.
when i dial up the weight there is no difference in cut depth.
So if i bring the blade down slightly its too deep for kiss cut.
I have tried setting up the two cut contours in Flexi with different weights and again no difference either cuts both all the way through or kiss cuts.
What am i doing wrong.
cyclerc
YOU ADJUST THE PRESSURE OF FLEX CUT IN CONFIGURATION SECTION IN THE DISPLAY. FLEX CUT PRESSURE ADJUST IN OTHER SECTION
