Mark Fackrell
I am having an issue with the blade depth on our Summa S2 T160. The job I am trying to setup would be CutContour and then FlexCut with about 1/4" of backer exposed around the sticker (after weeded). The problem I am having is when I set the blade depth to work with the CutContour I cannot get the FlexCut to cut all the way through (even at max pressure). OR if I set the blade depth to work well with the FlexCut, the knife will cut all the way through the material with the CutContour at zero pressure.
This is all happening using the "test cut" on the Summa interface. (no software interaction)
The adhesive material is 3 mil Gloss White Calendered Vinyl with a 90# liner (no laminate).
I'm hoping this is some kind of user error, and there is an easy fix.
We checked the blade and the roll mechanism to see if there was any gunk build up and it is clean.
The blade we are currently using is 45 degree.
Any help is appreciated... thanks!
