Summa S2T160 pinch rollers install
Discussion in 'Summa' started by iPrintStuff, Sep 23, 2020.
  1. iPrintStuff
    iPrintStuff Prints stuff
    960
    256
    63
    Sep 3, 2018
    United Kingdom
    As per name, anyone got a manual etc for fitting additional pinch rollers on the summa S class? Looks relatively straightforward but I’d like to make sure it’s done right!
    Our techs are currently refusing to come out and do “unnecessary” jobs but won’t release any info on how to fit them ourselves!
    TIA for any advice.
  2. Snydo
    Snydo Active Member
    549
    36
    28
    May 1, 2008
    Mid Michigan
    It's pretty straightforward and the included instructions are decent. I've done three, the first one took 90 minutes or more, the last one took about 20 minutes. If you remove the end panel completely, remove the ribbon cable from the board side, not the screen side as it's much easier to reconnect on the board side. I'd also recommend keeping track of your screws for the side panel, put the same screw back into the same hole.
  3. iPrintStuff
    960
    256
    63
    Sep 3, 2018
    United Kingdom
    They didn’t include any instructions- honestly the guys we got it through have been pretty useless.
    I asked for tech support the other week, they told me what I needed to do wasn’t possible and hasht ever been. Then I contacted onyx and got a patch for my issue - glad I double checked!
    Do you happen to still have the instructions?
  4. Snydo
    Snydo Active Member
    549
    36
    28
    May 1, 2008
    Mid Michigan
    I will look, pretty sure I do.
  5. Snydo
    Snydo Active Member
    549
    36
    28
    May 1, 2008
    Mid Michigan
    here you go.
    • Like Like x 1
    • I Appreciate You I Appreciate You x 1
