Summacut D160R - When loading, unrolls whole roll
MikeyG
Hi there
Got a new SummaCut D160R.
When loading media on it, it feeds the entire roll through the machine, then scrolls it all back again. (This could be a 30m roll of vinyl!)
Is there any way to stop the whole length of the roll from being fed through?
Thanks!
MikeD
There may be a problem with the media sensors; front &/or back. Try turning them off and see if the problem persists. It sounds like the back sensor is searching for the end of a "sheet."
Good Luck!
Miked
PHILJOHNSON
Sales Manager
Hi MikeyG,
One thing you might try is to disconnect the cutter from the computer and retry the autoload process. Sometimes there may be data that your computer is still trying to send to the cutter that may be causing it to feed further than normal. If the problem persists when the cutter isn't connected to the computer then I would try doing a factory reset to clear any corrupted data that might be causing these issues.
Please don't hesitate to contact Summa technical support at (800)323-9766 if you need a hand troubleshooting this issue further.
Thanks!
Best regards,
Phil Johnson
Summa Inc.
d fleming
Might be totally useless but on my graphtec when I load material among the options is rear set or front set. Front set will go to end of roll and back, rear set loads normally.
FatCat
Hi MikeyG,
Thanks!
Best regards,
Phil Johnson
Summa Inc.
And this folks, is why I'll never buy another brand of cutter than Summa. :rock-n-roll:
