Suppliers for Small Amount of Matthews Gold Paint?
Discussion in 'Dimensional Signs' started by rossmosh, Jun 2, 2019.
  1. rossmosh
    rossmosh Active Member
    687
    192
    43
    Oct 9, 2014
    New Jersey
    I have a project in the works and I've tried Modern Masters (hate it) and Nova Color (just satisfactory) gold paints. I'd like to go ahead and use the "industry standard" Matthews Brilliant Gold but I really don't want/need a gallon.
    Does anyone know where you can buy a pint or a quart?
  2. Eric H
    Eric H Member
    153
    7
    18
    Aug 1, 2006
    Pennsylvania
    You also need the hardener (and reducer if spraying), I'm not sure if it comes in smaller amounts.
  3. John Miller
    John Miller Member
    140
    80
    28
    Dec 10, 2005
    Branford, Connecticut
    Why do you hate Modern Masters? Their gold is a much better match to gold leaf than Matthews. We basically use Matthews whenever we are painting a sign but when we need a convincing gold our go-to product is MM. You need a light undercoat and then several coats of paint.
  4. rossmosh
    687
    192
    43
    Oct 9, 2014
    New Jersey
    MM has the worst adhesion on a paint I've ever experienced, bar none. When you go to peel the paint mask off on a V-carve sign, the gold paint that filled the letters come off with it. I've tried paint directly onto PVC (no primer). I've tried primer. I've tried putting an under coat. I've tried scuffing the under coat (which is a huge PITA when you're talking about V-carve letters).
    On raised letters, it's fine. No mask, it's fine. On V-carve, it's garbage.
