switching back to eco max inks from sub inks (SP300) possible?
CustomRide
I was wanting to know if anyone has tried switching from Dye sub inks back to eco sol maxs inks in the roland sp300? Im assuming everything would need to be replaced on it internally. Just curious cause we found one at a good price. Any techs out there interested in replacing the parts PM me if your around southern ohio.
Jack Knight1979
well the standard protocol is to flush the ink out with the cleaning fluid for that particular ink.
I then flush that out with the new flushing fluid. You don't have to do this step, but I like to.
After the cleaning fluid has been put in you can pump up the new ink.
I would then change the dampers as they will potentially hold some of the old ink. You don't want anything mixing.
