T Shirt Vinyl
NgnEngraving
Hi all,
I am having trouble using printed T Shirt vinyl, It seem very stretchy after being printed on and the cutting is not separating the edges properly, but it cuts all other vinyl fine. Any clues as to what I'm doing wrong? and any help?
Mike_Koval
if you are cutting to the edge of the ink, it is best to allow some dry time prior to cutting....especially with stretchable materials.
ironchef
All other vinyl? As in non tshirt material? Every media type will need different pressure settings for the blade, for example, when my avery and oracal cut vinyl need diff. Settings, oracal needing way more pressure.
