When deciding on a heat press ask youself these questions...
1. How much room do I have?
If you are limited in space, you're best option is the clam shell. These units take up little space and can be placed just about anywhere in your shop. Another nice feature on some clam shell is the auto release feature. Perfect press for those doing small amounts of transfers and busy shops where the auto release feature comes in very nicely...no baby sitting.
2. What are my main applications?
If you are doing alot of layout such as names and numbers, no question a swing away or a draw style. Heat free work space and no burny fingers! Also if you are doing items such as bags, totes and other odd shaped items, a press that allows for threadability is key...the new
Hotronix Fusion is perfect for this.
3. What is my volume of presses?
If you are doing a high volume of pressing, you may want to consider an air operated swing away press. These units are completely automatic. Close with a push of a button and open automatically. This will save wear and tear on the operator.
Answer those questions and then look at the extras. For me a must would be digital time, temp and pressure readouts, and if going with a clam, auto release.
