Bly
I don't know how long is your experience on tangential cutters, I can only tell you they are much more sensible to the user settings, expecially the knife depth, than drag cutters. This is the reason because many have asked you to verify it.
Can you tell us which components have been replaced by the technician? The entire tangential head or others?
Yes I'm aware.
As stated in my original post, the knife depth and pressure seemed fine at the start of each job, then after running for a while you could hear the tool being mashed into the vinyl much harder, ruining the job. There is clearly a fault with the machine.
I'm not sure exactly what the tech has swapped - I think it's been a process of elimination.
He did mention he wanted to swap the whole head but the one their interstate office sent one without OPOS Cam, so I think he just swapped the up/down encoder.
This enabled me to use the machine again but with some errors.
They are getting the correct head for replacement as far as I know.
