Target Registration Edge FX and Envision 375
artofacks1
Hello,
I printed with the Print Target Centered.
Than I tried die cutting it with the 375.
I aligned the blade to the center. Than the machine gave me an error that it did not fit.
I proceeded and said to align itself.
However, the cut is off. I am thinking I should have the Print Target , print Lower/Left instead and than align it that way.
here are some pics of the test.
P.S. I already sent GMS and email. However, I work nights with my equipment and I might get help from the community in the meantime.
Thanks!!!!
I can email the file to anyone that has time as well. It can be that the set up is wrong.
artofacks1
Another thing that I might be doing wrong is outputting from Composer (Output By Layer)
I was thinking if I choose (OutPut All) Than print and cut from GSPlot from the same file it would register right.
Anyhow, good night and thanks for reading and helping in advance.
J Hill Designs
I usually 'output selected' since I have multiple items on my file (usually)
edit: YES print and cut from the same gsplot item
J Hill Designs
just select what you want to print/cut using output selected
in gsplot check the 123 button to make sure output order is all correct, all set to same vinyl, etc
print
put in plotter
cut
artofacks1
print
put in plotter
cut
It just seems like output selected moves the cut layers position. When I do that from composer.
Another thing I am going to try tonite is the auto align feature in Omega.
signage
What you can try to see if everything looks correct is to output to a spool file and view it first!
What is the overall size of the complete job? Do you have weed boarder selected?
artofacks1
Print and cut test is now a success.
Thanks for everyone reading and/or replying to my threads.
Big Ups, To Doug GMS!!! He is a master of the Gerber products! I am extremely thankful and please with the support from GMS!
signage
GMS is a great group!
Rather than just give credit to them you should let everyone know what you did to correct it so others that may have the problem and searching will find the answer rather than just the problem!
MikeD
+1 to Graphic Marking Systems!
I would first check for extraneous points in your design that may be out of bounds. Next I would run the "calibrat" file Gerber provides. We typically output via GSP Plot versus outputting from Composer.
Good Luck, and please share how you ended up resolving the issue.
miked
