Tearing Top Layer of Vinyl
Xamm_
Hi guys,
We're trying to use our MultiCam (Australia) to do a bit more for us in our shop. We're having a bit of trouble after laminating prints with UV clear on to 3mm aluminium (0.118 inch) with the top vinyl edge not cutting cleanly, but rather tearing it a bit.
We've done a bit of experimenting and are mostly happy as the edge only takes a quick sand and it's good, however looking for a few tips pointers to get a clean edge in one go.
Thanks for any assitance
Xamm_
I have had better luck with a V bit... and then a end mill if the lower edge is too sharp for you.
Thanks for the helpful response - will give it a go. In the mean time we tried a new bit... broke it then tried another new bit and it cut perfectly! Weird world.
On a second note, anyone cut 5005 grade aluminium without oil lubrication?
Ditchmiester
Thanks for the helpful response - will give it a go. In the mean time we tried a new bit... broke it then tried another new bit and it cut perfectly! Weird world. On a second note, anyone cut 5005 grade aluminium without oil lubrication? Thanks
I've cut 5052 aluminum with no lube. Just take a more conservative approach towards the tool paths. If not you will generate way to much heat and burn up your tools.
