Techno introduces The LC Series CNC Router
hrarum
LC SERIES CNC ROUTER
Where Quality Meets Economy
Superior Components
Equal
Superior Quality
  • [SIZE=-1]Closed Loop Servo Control System
    [/SIZE]
    [SIZE=-1]Servo Motors provide more power when you need it (even at high speeds) and do not lose position. They constantly check and maintain their position, making perfect parts every time.[/SIZE]
  • [SIZE=-1]Ball Screws On All Three Axes
    [/SIZE]
    [SIZE=-1]Ball Screws ensure accurate cuts and extend the life of your machine. Their rolling contact design creates a sturdy play-free motion that requires minimal maintenance while providing high degrees of accuracy and repeatability. Less expensive alternatives wind up costing more in downtime and repairs.[/SIZE]
  • Construction Features
    Techno knows that good quality routing is built from the ground up. Our engineers (with over 18+ years of CNC design experience) follow aircraft design principles in designing machines. The LC Series design includes a heavy steel-base frame, Techno's proprietary aluminum T-slot table, and a one piece X/Z axes beam construction of extruded aluminum (with internal reinforced webbing and hardened steel rails/bearings). This design is extremely rigid yet light enough to travel at high speeds, minimizing vibration while increasing accuracy and repeatability.
  • [SIZE=-1]Windows-based CNC Gcode Interface
    [/SIZE]
    [SIZE=-1]Techno's extremely easy to use CNC Interface is a great bonus that is bundled in our machine sales. It's single-screen design makes CNC as easy as 1-2-3. Most CNC functions (i.e. Built-In G-code Editor, production logging and reporting, infinite look-ahead and continuous motion, toolpath and part preview) are just one click away feature intuitive controls. Also, it comes standard with FREE lifetime updates via the techno support website. [/SIZE]
SMALL INVESTMENT
BIG RETURN
[SIZE=-1]Another advantage of Techno's 18+ years of CNC expertise can be seen in the modular design of the LC Series. You can purchase a base LC Series machine for a small initial investment and then build as you go. Add a spindle with more HP, a vacuum table setup for greater part holddown, 3D scanning for reverse engineering, or a rotary table for 4th axis routing. Add them as your growing business and applications require. The average Techno customer pays for this machine within six months of purchase. It's easy to setup, learn and use. The LC Series will increase profits and production, improve cut quality while also decreasing overhead.[/SIZE]
The LC Series Will Provide CNC Solutions for Your Business
:wavingflag:
