Temp for printing on Oracal 651
Shadowglen
I am printing on Orange and Yellow Oracal 651 vinyl. just black print. using a Roland sp540 I. print heat is set to 42*c 107.6 f and the Dryer heat is set to 45* c (113) f. The vinyl is getting wavy after the pinch rollers and the head was scraping in a spot towards the edge. I have installed the larger media hold downs but was wondering if my heat should be at. With the machine off the vinyl is not wavy. any advice would be great. Thanks Dave
Mike Paul
Super Active Member
651 is for cutting not printing.
I guess your printing on it so you have a vibrant Yellow or Orange so you need to fiddle w/ the heat settings.
Sign Works
I do this quite frequently on my SP-300V without any problems although I do use the 751.
Default heat settings are 37 & 40 and that's where they stay. Turn down your heat a bit and you should be good.
danky01
I didn't know you could print on regular cut vinyl, I though it had to be inkjet vinyl. Is print on the 651 as durable as on the 3651?
CP Signs
If you lam it yes. You'd be surprised what they can print on. Like most here know, if you're stuck and need to print on clear, print on lam,,,,, not the same as clear vinyl but works.
Drip Dry
Try giving the supply roll some slack. I find I get the wavyness and head strikes when it's trying to pull off the roll
psbc2009
This. I used to immediately go to the heat settings But I have found that tension is just as important. Supply roll tension and or take up roll. Not sure why but lately I've had to turn the temperature down on all medias And usually put a Slack loop on the supply side. It's fine to print on 651 there is just a better chance for contaminants on the media.
Patentagosse
I print on silver metallic (cast) on regular base. The ink of my Roland are kinda translucent so I can use silver met. to create a bunch of new metallic colors (Candy Apple-like). 'Prints fine but you just need to make sure there's no contaminant. On new rolls, it's pretty safe as no human handling is done at most factories as far as packaging.
danky01
Would it be possible to print an opaque image on a clear acetate? I use my Versacamm to print artwork for burning my screens for screen printing. I have been printing on clear window cling which isn't the best material to work with.
danky01
Well I answered my own question last night, and it is a big fat NO!! I did try printing on laminate, as has been suggested and that worked great, and its much easier to work with. Now this has me thinking, what else could I print on.
