Text Distort In Flexi 8.5
sghobbies
There is a text distort that I am trying to do, but can't seem how. Not sure what it is called, but the top(or bottom) of the text is straight, and bottom has an arch effect. Can this be done with Flexi 8.5?
cgsigns_jamie
Effects Menu > Distort
Then select the distortion type in design central.
What version of Flexi are you running (Pro, Expert, Designer...) Certain versions don't have the effects.
sghobbies
I am running Pro, which I just upgraded to. I was using lxi expert, and I could have sworn that I had that distort in the menu, but I know I don't have it in the 8.5 pro menu
cgsigns_jamie
I don't have Flexi at the house so I can't show you a screen shot but I sure that the distort you are looking for is there.
I'm sure someone here will be able to guide you in the right direction.
Kenny
The Distort you want is "Arc-top"...apply it and right below the image in the DesignCentral dialog you can mirror the effect to be top or bottom.
PMG
Same as kenny said........
sghobbies
Here is a screen shot with the distort menu in design central.
PMG
you got it.........its the next one over from what you were using in the snap shot...once you apply it...pull the handles down.
PMG
SWEET!:U Rock:............Got it..........I feel like an idiot now. :covereyes:
Thanks to all for your help.
Dont feel that way..this is what 101 is all about......just return the help to someone ....it makes this a better place:peace!:
