Text paths in AI & cutting master
Discussion in 'Adobe' started by geek_riot, Jun 18, 2005.
  1. geek_riot
    geek_riot Member
    41
    I have a graphic I am cutting, and one of the lines is in a script. When I convert to paths, obviously the letters are separate, even though they look connected. Is there any way to connect these letters so that when I cut, I don't get separate letters. I am finding it difficult to weed, as the letters are thin. It seems that it would be a whole heck of a lot easier if the words were conencted.
    Also, using cutting master, I seem to be having a hard time figuring out what to size my document at so that it matches the roll size.
    Thanks in advance for the help/advice.
    Kim:thankyou:
  2. Fred Weiss
    Fred Weiss Merchant Member
    20,920
    545
    113
    Sep 11, 2003
    Olympia, WA
    You need to weld the script letters. In Illustrator, select the text and execute a Pathfinder > Merge command.
  3. geek_riot
    geek_riot Member
    41
    Ok, I am using illustrator 8 right now. Is this feature available?
    Kim
  4. geek_riot
    geek_riot Member
    41
    ok, sorry, i'm an idiot! It was right under my nose! Thanks Fred!
    Kim
