Text to Shape CS2...
Discussion in 'Adobe' started by WVB, May 4, 2007.
  1. WVB
    WVB Very Active Member
    2,749
    For the life of me I can not remember how to make text take on the shape of an object. Lets say you have an oval. You want the text to fill the inside of this oval. Delete the oval and the shape now looks like an oval. I know you can do this with the warp/bulge but it looks bloated or 3d as if the text is coming at you from the middle... I know there is another way to do this...
  2. vid
    vid Very Active Member
    1,442
    3
    38
    Jun 11, 2003
    California
    Object > Envelope Distort > Make with Top Object?
  3. WVB
    2,749
    Yeah, I tried that too but kept giving me this error msg:
    This requires a selection of multiple objects. The top object must be a single path or mesh, or a symbol containing a single path or mesh.
    Which it does from my understanding. Its an oval..?
  4. ChicagoGraphics
    ChicagoGraphics Major Contributor
    4,812
    59
    48
    Feb 27, 2007
    World
    Dont you make your shape, then type your text, then highlight the 2 then mask?
  5. mondo
    mondo Active Member
    562
    Try > Layer -> Type > Warp Text.
  6. javila
    javila Active Member
    843
    Make a path(any type, path alone or shape layer). Then select the text tool. Hover over the path and it'll change to the path type tool.
  7. vid
    1,442
    3
    38
    Jun 11, 2003
    California
    Sounds like your text is in the foreground...
    Is this what you're trying to do?...... The images above are before I applied the Envelope Distort w/Top Object. The bottom images are the result.
  8. WVB
    2,749
    Yes VID, this is what I can do utilizing the envelope warp tool.(left bottom hand side) How did you do the one on the bottom right hand side..?
  9. vid
    1,442
    3
    38
    Jun 11, 2003
    California
    I just clipped the ends off an oval and used that as my envelope object.
    Step by Step:
    Drew an oval > Drew a rectangle taller and narrower than the oval > Align center and horizonal > intersect (expand)
    Typed Text > Sent to Back >...
    Object > Envelope > Make with Top Object.
    bbbbbbuuuut, just trying the way you describe you're doing it (the Bulge with the Envelope Warp) I'm getting the same thing as the bottom right (?)....
    In either case you can use the white arrow on the control points to adjust it to the look you're trying to acheive.
    Hope that's not confusing and helps.....
  10. tintguy31794
    tintguy31794 Member
    158
    It helped me :p
