Pauly
Printrade.com.au
This will sound very newbie...
But we've been getting a little more requests to print wallpaper.
I have a roll of low tack wallpaper that an easy install. It's thick, so you dont need to overlap them as you can but them together nicely.
its roughly 1300mm wide
I would generally just pre cut lengths, say 3 lengths of 2m long. i'll put them on the UV flatbed and print edge to edge. So they join easily but it's a bit of a process when i need to print a bunch of it
So if i where to put it on a roll to roll, would you print it say 1200mm with 50mm blank on each side for example and somehow trim the sides?
What's the go to - appropriate method?
Hope this makes scene,
TIA.
TIA.
